Problem... Help...!
Old Oct 3, 2006 | 10:24 PM
Izero's Avatar
Izero
Default Problem... Help...!
Hey guys, i opened my hood today and i noticed that i am leaking oil out of where the spark plug wires go down into the engine to the spark plugs, its only leaking out of the one all the way to the right... and its fresh oil... do you think its a blown seal or piston ring or what?
Old Oct 3, 2006 | 10:31 PM
fraggle_a's Avatar
fraggle_a
Default RE: Problem... Help...!
Clean it out.
Then reseat the plug.
Clean the engine off, then run it for a little while.
Shut it off, let it cool, then run your finger around the engine and see if you can feel where the oil might be comming from.
(or, blow dust on the engine, it will stick to the oil on the engine and make it easier to see)
Old Oct 4, 2006 | 04:20 PM
tooslow's Avatar
tooslow
it is the spark plag tube seal just pop of the vavle cover replace them only tools needed is a 10mm socket and get a new valve cover gasket it should take 15min too do
Old Oct 4, 2006 | 06:24 PM
NHARINTON's Avatar
NHARINTON
Tube seals as "tooslow" said, i did it about a week ago. When you buy the valve cover gasket set it comes with the tube seals!!
i think i paid like 15 bucks at autozone for the whole package! took me 20 min.
Old Oct 11, 2006 | 10:07 PM
Izero's Avatar
Izero
do you know the part number by any chance? or do you have a link to the part? as i'd like to go there and just ask for what i need by part number......
Old Oct 12, 2006 | 07:04 PM
NHARINTON's Avatar
NHARINTON
for a 2003 se it is:
FELPRO
Autozone part #VS50507R
autozone.com helps, it can shop by year make and model
Old Oct 12, 2006 | 11:02 PM
Izero's Avatar
Izero
ok..... well i think im just gonna go there and see what they have.... b/c i cant seem to find the right part on there.....
Old Oct 13, 2006 | 12:17 AM
NHARINTON's Avatar
NHARINTON
try this see if it works, copy and paste it:
http://www.autozone.com/servlet/UiBr...e+Cover+Gasket
Old Oct 13, 2006 | 01:21 AM
Izero's Avatar
Izero
it works... i guess ill just write down the part # and head over to my local autozone and pick it up hopfully they have it.... they should.... thanks for the help... and are there any serious risks with the problem i am having? or am i ok to drive tomorrow and possibly the next day....?
Old Oct 13, 2006 | 04:19 PM
NHARINTON's Avatar
NHARINTON
not really any risk, maby just losing oil and some misfires cause the plug is soaking. I dont know how long i had been driving. i was on original plugs and when i wint to change them i found the oil so who knows how long it was thier. I would not worry, but dont wait a few months.
