Do I need to buy a Camber Correction Kit?
I'm planning on buying Progress Springs today or tomorrow. Do I have to purshase a Camber Correction Kit with it as aswell? Is it required? If not, what are the pluses and minuses? They're an extra $50. : / On a sidenote, can you guys tell me a little bit about what kind of difference I'm going to feel with the new springs?
you actually might how much of a drop is it. i dropped my car 1.4 in and it threw the camber off so i needed to adjust the camber with a kit pain in the *** geting it right
most likely you will need camber kits in probably all 4 struts. i have no experience with those, and i cant imagine how to adjust them with those crazy washer thingys but i'm sure someone will
if you want, lower your car then check your alignment. that will tell you if you need them. you will need analignment when you lower it anyway, and camber kits will most likely be required
It would help to get it back to best settings for best tire wear. But in a performance setup it may be pretty good without it but you may even want more in some circumstances.
