Turbo Manifold Question
Old Oct 13, 2006 | 05:11 PM
Silver04SXT's Avatar
Silver04SXT
Default RE: Turbo Manifold Question
Thanks for your input everyone....as far as piping its the piping for the stock air intake that im talking about. Now as far as the ECU, i know i will have to upgrade, correct?
Old Oct 13, 2006 | 05:36 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Silver04SXT
Unless you want to go MegaSquirt you dont touch your ECU...well you technically touch it because you have to move it but your not replacing it (unless you go MS). If you do not use MS you will be using a RRFPR fuel system.
Old Oct 13, 2006 | 09:38 PM
spikeymikey87's Avatar
spikeymikey87
hey 03neonRT i thought you had the pipes from an srt to put in and only the hot side was cut and theres like a rubber bendy piece there
Old Oct 14, 2006 | 05:19 PM
03neonRT's Avatar
03neonRT
ORIGINAL: spikeymikey87
I was going to try and use the stock coldside pipe and mod it a little to fit with my Turbo XS BOV but when i did a test fit the piping wasnt matching up with the TB quite the way i would have liked. I'm still using a modified stock SRT-4 hotside pipe, but i decided it would be easier, and look better if i just used some bends, silicon couplers, and aluminum piping that i could cut into whatever lengths i needed them to be.
Old Oct 15, 2006 | 12:28 AM
spikeymikey87
o cool can you send me the specs of what you used because i might end up doin that too then
