Turbo Manifold Question
Old Oct 11, 2006 | 09:42 PM
Silver04SXT's Avatar
Silver04SXT
Default Turbo Manifold Question
Hello everyone, Im new to the forum I have an 04 Neon SXT. I recently purchased an '05 stock SRT-4 Turbo with manifold and piping from ebay. I've been told that the stock Srt4 manifold will not fit my SXT, i found this out after purchasing the parts. Can someone help me out wiht this? If this is true what choices do i have? I want to be able to use the stock turbo.
Old Oct 11, 2006 | 11:27 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: Turbo Manifold Question
go to i think maybe n e o n s . o r g and theres someone there named maddog and he makes adapters for 216 with both gaskets. i think hes from there i cant really remember even though i gotta buy one of those anyway but someone correct me if i'm wrong. aldo check the turbo sticky because the turbo isnt all you need
Old Oct 12, 2006 | 05:01 AM
03neonRT's Avatar
03neonRT
Correction for above...
Mattdog = manfiold adaptor plates
Maddog = sweet short throw shifters
And yes it is $216 shipped with four gaskets.
Old Oct 12, 2006 | 12:21 PM
spikeymikey87
right mattdog i thought there was something wrong there
Old Oct 12, 2006 | 02:41 PM
03neonRT's Avatar
03neonRT
I want to know what he means by "piping"...because if he's talking about the IC piping, i hope he knows it wont fit properly and he's going to chop it up...if he's talking about the oil/water lines he's going to need to modify the stock lines or get some SS lines and fittings...
Old Oct 12, 2006 | 03:16 PM
tooslow's Avatar
tooslow
for me the stock hot side piping worked fine. but I had too lose the tranny brace bracket also had too reloacate the ps cooler. the cold side is pretty easy too do 2 90deg elbows and piece of pipe about 12 in long and you are golden
Old Oct 13, 2006 | 01:37 AM
spikeymikey87
can you make intercooler miping out of another material that you can get at like a home depot or something it might be ghetto but if it works why not
Old Oct 13, 2006 | 04:18 PM
03neonRT's Avatar
03neonRT
Well for hotside i think you need metal piping...but for coldside you can use any material you want. Take the SRT-4 stock piping for example, hotside piping is a metal and coldside is a rubber composite piping.
Old Oct 13, 2006 | 04:37 PM
tooslow's Avatar
tooslow
I used some exhaust pipe and some of built our own intake elbows from pepboys for the cold side
Old Oct 13, 2006 | 05:07 PM
03neonRT's Avatar
03neonRT
ORIGINAL: tooslow
Yeah thats pretty much what i ended up doing as well...
