from 2.0 to 2.4
Old Oct 16, 2006 | 07:13 PM
2001dodgeneon's Avatar
2001dodgeneon
Default from 2.0 to 2.4
sup!?!?, i have a 2001 dodge neon and i can get my hands on a 2.4 turbo motor out of a srt4 neon...........and i was wondering if anyone knows if the trany that is in my car will bolt up to that motor? and if the motor mount are the same? i kno that i will need a srt-4 wiring harnest....... i guess what i realy need to kno is what all will it take to make the swap complete!
thanks,
Brady
Old Oct 17, 2006 | 03:40 PM
03neonRT's Avatar
03neonRT
Default RE: from 2.0 to 2.4
ORIGINAL: 2001dodgeneon
thanks,
Brady
Here is everything you need to do the swap succesfully and completely...and no, the T350 tranny will not work with the 2.4.
[ul][*]Engine and Tranny[*]Complete Engine Wiring Harness [*]Complete Engine Bay Wiring Harness [*]Power Steering Pump, lines, and cooler [*]Clutch master and slave cylinder [*]Clutch/Brake Pedal assembly [*]Intercooler Piping [*]Intercooler [*]Radiator Hoses [*]Tranny, Upper and Lower Motor Mounts (the holes are larger on the the upper and lower mounts for larger bolts and the tranny mount is completely different) [*]SRT PCM (wont' need the bracket with 03+) [*]Axles (and half shaft if it isn't on the engine) [*]Coolant Bottle [*]Fuel Line from tank to engine bay [*]Fuel Pump [*]Flex Fuel line from solid fuel line to fuel rail [*]Short evap hose that comes from the purge valve [*]All vacuum lines and the 3 selonids [*]o2 Sensors [*]Turbo Housing + o2 Housing [*]Lower Control Arms (they're stronger yet the same in shape) [*]Sentry Key Module + Key that matches the PCM VIN number. [*]Radiator (aren't totally sure if this is an absolute need) [*]Radiator Fans (it's a dual fan setup) [*]Shift Cables
[*]SRT Power steering rack (it's shorter) [*]Knuckles [*]Flexiable Brake Lines [*]Calipers [*]Rotors
[/ul]
