UDP ?
Old Oct 20, 2006 | 03:11 AM
03neonRT's Avatar
03neonRT
Default RE: UDP ?
ORIGINAL: moobit
dang, so its two belts?
Yes.
Old Oct 20, 2006 | 03:26 AM
moobit's Avatar
moobit
Default RE: UDP ?
ditto! thanks. One more question, where does the accesories belt go or where is it at?
Old Oct 20, 2006 | 03:35 AM
03neonRT's Avatar
03neonRT
Default RE: UDP ?
ORIGINAL: moobit
The accesories belt drives the power steering and A/C...the crankshaft pulley has two belt "slots" on it...the Acc. belt is much longer and will go through a tensioner and attach to the Acc. pulley (the alternator belt is smaller and attaches directly from the crank pulley to the alternator pulley). Its probably easier if you just went out to your car, loosened the lugs, jack up the car, remove the wheel, remove the splash guard, and you'll see the crank pulley...open the hood and you'll see the Acc. belt pulley and tensioner to the bottom left of the engine bay.
Old Oct 20, 2006 | 03:38 AM
moobit's Avatar
moobit
Default RE: UDP ?
got it. thanks.
