UDP ?
Old Oct 17, 2006 | 04:18 AM
moobit's Avatar
moobit
Default UDP ?
Any one heard of a megan underdrive pulley, any good? thanks.
Old Oct 17, 2006 | 03:32 PM
03neonRT's Avatar
03neonRT
Default RE: UDP ?
ORIGINAL: moobit
Basically the same as the MPx or Unorthordox Racing ones.
Old Oct 18, 2006 | 01:23 AM
sxt_seven's Avatar
sxt_seven
Default RE: UDP ?
replace the UDP from the stock there a piece of junk!!! and the aftermarket ones will let up some more power
Old Oct 19, 2006 | 03:08 AM
moobit's Avatar
moobit
Default RE: UDP ?
Im getting one used off somebody, what usually comes in the package, any extra hardware or just the UDP itself? thanks.
Old Oct 19, 2006 | 10:00 PM
CA180's Avatar
CA180
Default RE: UDP ?
I got one used... All it is is just the UDP. You use the original crank bolt. You will need to get belts, The stock belts will be too small and I wouldnt used old belt anyone gives me. I have heard many diff parts numbers for belts, but they were all to ong for my '05. I picked up a set of Gates belts from O'reilly's. Parts numbers are: K040305 -this is the alternator belt 31-1/4" ---- K040490 -this is the accesories belt 49-1/2"
Hope this helps out. These belts may not be the same for you, but they were perfect for me. Many people complain of the accesories belt shredding, but the ones supplied from MPx are too long (IMO)
Anyways, good luck... Later
Old Oct 20, 2006 | 02:17 AM
moobit's Avatar
moobit
Default RE: UDP ?
I just replaced my belt like two weeks ago, that means i have to replace it again?? dam. So i need a longer belt for this??
Old Oct 20, 2006 | 02:23 AM
03neonRT's Avatar
03neonRT
Default RE: UDP ?
ORIGINAL: moobit
Correct.
Old Oct 20, 2006 | 02:25 AM
moobit's Avatar
moobit
Default RE: UDP ?
Do u happen to know the specific size for the belt?
Old Oct 20, 2006 | 02:40 AM
03neonRT's Avatar
03neonRT
Default RE: UDP ?
ORIGINAL: moobit
The NAPA part numbers are 25040320 ($12- Alternator belt) and 25040500 ($20- Accesories belt ).
Old Oct 20, 2006 | 02:55 AM
moobit's Avatar
moobit
Default RE: UDP ?
dang, so its two belts?
