Where is the Oil Pan?
Old Nov 4, 2006 | 06:13 PM
LumberJack's Avatar
LumberJack
Default Where is the Oil Pan?
Where is the oil pan on my 2005 sxt? and how do i drain it?
Old Nov 4, 2006 | 06:50 PM
QBall02's Avatar
QBall02
Default RE: Where is the Oil Pan?
Under your engine. To drain it you remove the oil plug which is nothing more than a bolt.
Altho if you are asking such a basic question, maybe you shouldnt be draining it.
Old Nov 4, 2006 | 07:02 PM
ewetho's Avatar
ewetho
Agree with last post. Have someone show you directly in your presence.
Old Nov 5, 2006 | 03:17 AM
04 mo neon's Avatar
04 mo neon
Yeeeeaaaah, that would definatly be under the car. lol
Old Nov 5, 2006 | 03:42 AM
Mullet Man's Avatar
Mullet Man
I would spend the $20.00 for an oil change my friend.
Old Nov 5, 2006 | 11:07 PM
NHARINTON's Avatar
NHARINTON
just so you can learn, jack your car up... put it on jack stands so you dont get crushed!!!! Then look for the honeycomp looking pan directly under the engine, thier is a bolt (i think it is a 10mm) on the back bottom side, with a oil pan right under it remove the bolt..... oil will stream out, when it has stoped remove the oil filter again with the pan under it..... when all the oil has stoped dripping ( i still dump one bottle of oil in just to flush it) reinstall the bolt and new oil filter. (make sure to put some oil on the cork gasket on top of the new filter... or it will leak) fill with oil through the oil cap on top of the engine. start the car.... make sure of no leaks and bam you done!!!! should take no more the 30 min. your first time, after a few times you can do it in about 10-15 min. max!! good luck!! EVERYONE NEEDS TO KNOW HOW TO CHANGE THIER OIL!!!
Old Nov 6, 2006 | 01:03 AM
03neonRT's Avatar
03neonRT
Haha I'll have to take pictures when i do mine this week just for the hell of it...
Old Nov 6, 2006 | 04:38 AM
kishore's Avatar
kishore
Its 13mm bolt and yes it took me 30 minutes first time now i do it in 10 minutes the delay is for the oil to flow out.
You will also need a wrench for the filter.
Old Nov 6, 2006 | 09:26 AM
spudsterier's Avatar
spudsterier
you wont always need a filter wrench if it on there correctly.....if you dont have a filter wrench and its on there kinda tight then you can use a screwdriver and a hammer....ive had to do it that way alot of times
Old Nov 6, 2006 | 03:59 PM
slyrby's Avatar
slyrby
ohhhh... thats how you change the oil! naw... just kidding lol
