snails
Old Nov 8, 2006 | 12:05 PM
fullbuilt's Avatar
fullbuilt
Default snails
is anyone else out there turboed and what have you done.
Old Nov 8, 2006 | 11:58 PM
GrApHite03's Avatar
GrApHite03
Default RE: snails
219whp / 244wtq http://i13.photobucket.com/albums/a2...12_05_dyno.jpg
Interior:
McFab STS | Solid Shift Cradle Mod | Booger Bushings | SRT-4 Viper Inspired Seats
Exterior:
De-Badged | Shaved Door Moldings | Euro Clear Corners | Euro Clear 3rd Brake
Engine:
Unorthodox UDP | ACR Gears 3.94s | ACR Head | Head Spacer | 2 Felpro Head Gaskets | "mattdog" SOHC to DOHC Flange Adapter | SRT-4 Turbo | SRT-4 Exhaust Manifold | SRT-4 FMIC | SRT-4 Hard Pipes - Hot & Cold | Stage 0 SRT Injectors | BMW Cold Start Injector | Aeromotive 1:1 FPR | Walbro 255 | Custom return line | SPEC Stage 2 Clutch | SRT-4 o2 Housing | CherryBomb Glasspack | SRT-4 Rear Section | Needswing 3' to 3" Cat Delete/ Electronic Cut-Out | 8.5mm Fire Wires | Grounding Kit | Motor Mount Inserts: Lower Torque Arm & Tranny | Solid AFX Upper Torque Arm | Greddy Type-S BOV | Ebay MBC
Suspension:
Mopar Lowering Springs | Front: Sway Bar | Front: Strut Bar
In Car Electronics:
SAFCII | Autometer EGT | AEM UEGO Wideband | Auto-Meter CF 30 psi Boost Gauge
k3v
Old Nov 9, 2006 | 04:59 AM
fullbuilt's Avatar
fullbuilt
Default RE: snails
now thats a beutiful setup. its a shame we cant race sometime.
Old Nov 9, 2006 | 10:46 AM
spudsterier's Avatar
spudsterier
Default RE: snails
where does the line from the t-fitting go thats before the regulator????
Old Nov 9, 2006 | 04:08 PM
fullbuilt's Avatar
fullbuilt
Default RE: snails
if I understand your question right it goes direct to the fuil rail.
Old Nov 9, 2006 | 04:18 PM
spudsterier
Default RE: snails
i mean there is the line that comes out of the fuel rail, then goes to a T, then to the regulator....
what im wondering is wher does the line that comes of of the T thats is facing the front of the car and then curves down go to???
Old Nov 9, 2006 | 06:37 PM
fullbuilt's Avatar
fullbuilt
Default RE: snails
there are two fuel lines the one onthe right goes to the fmu and the one on the left is split behind the fmu.
Old Nov 9, 2006 | 07:07 PM
GrApHite03's Avatar
GrApHite03
Default RE: snails
5th injector plumbed into the intake. (after the TB) Its run by a 4psi boost switch.
k3v
Old Nov 9, 2006 | 11:25 PM
tooslow's Avatar
tooslow
Default RE: snails
nice I like it looks clean mine is way more cluttered mostly wire going every were.
