Help - not getting codes
Old Nov 10, 2006 | 02:09 PM
hecace's Avatar
hecace
Default Help - not getting codes
Not sure why, but I get no codes at all. the light works, but no codes. Also not firing at the plugs. Any thoughts??
Old Nov 10, 2006 | 02:34 PM
fullbuilt's Avatar
fullbuilt
Default RE: Help - not getting codes
if your not getting the done code on your speedomiter then your not turning it fast enough. if you are then you may have to crank the hell out it till it has somthing to read somtimes it takes a while.
