What do you think?
Old Nov 30, 2006 | 04:01 AM
JTM78's Avatar
JTM78
Default What do you think?
I'm graduateing from a automotive tech school tomarrow. The company I'm working for is going to pay me 48k a year. So what do you think about the Hahn racing turbo, 2nd stage? Do you know if it comes with a reflashed ECU, a stand alone, or will I need the MS that everyone talks about? I have disc, drum set up. How much to go with disc all the way around and the abs system because mine doesn't have abs. The suspension is stock, any ideas on that? Any ideas would be very helpful!!
Old Nov 30, 2006 | 04:26 AM
NHARINTON's Avatar
NHARINTON
Default RE: What do you think?
I myself am not that great on turbo's but i do know we will need to know the year and model... Se/sxt!!!
Old Nov 30, 2006 | 09:56 AM
chazlewood75's Avatar
chazlewood75
You can always upgrade the suspension which makes any Neon even more fun to drive. You may need to upgrade to wider wheels and tires too so you have more rubber on the road for take-off and stopping power. Great brakes and more power is no good if you are on ice-skates.
Old Nov 30, 2006 | 01:44 PM
04 mo neon's Avatar
04 mo neon
The HRC stage 2 is a very good kit and it's a good starting point. I would go with it and I dont think the MS is neccesary the kit should work fine with out any additional parts.
Old Nov 30, 2006 | 02:10 PM
fullbuilt's Avatar
fullbuilt
if you can find a junker r/t get the rear discs by tacking the hole tower thell swap up nicley
Old Nov 30, 2006 | 05:42 PM
03neonRT's Avatar
03neonRT
ORIGINAL: JTM78
Hahn has solid engineering and you cant go wrong spending the extra money for their products. You will need to choose either MS or a RRFPR for your fuel...but MS will allow you to control fuel, spark, boost control, nitrous, etc...If you have the know-how go MS right off the bat to control fuel and spark. To get rear discs you can either find a junked R/T or SRT-4 and swap everything...the R/T and SRT-4 rear discs are identical IIRC. Suspension, get some nice coilovers (Eibach, Tein, KSport, etc...) and some nice wide tires...with the coilovers I believe you can go to the 8" wide tires.
