Engine Shutdown / Oil Light
Old Dec 1, 2006 | 07:16 PM
bennyhonda's Avatar
bennyhonda
Default Engine Shutdown / Oil Light
I'm trying to help my girlfriend out with her 2002 Neon Sedan. I dont know much about these things but I do know you guys come highly recommended.
We got a check engine light last night so we opted to take the car for a free diagnostic today at Autozone. When I started the vehicle this morning I got the check engine light again, then the engine turned off. The oil lamp came on and a little red circle blinks below it.
I checked the oil, it's right where it should be. I checked the radiator, full and no oil mixed in. Then I took the batt cable off to reset the system only to repeat the problem
I cant diagnose the car unless I get it running or have it towed. Hopefully this will be covered by warranty though I havent read through the policy yet. Does anyone have any suggestions that may shed some light on the situation?
Thank you in advance.
Ben B
Old Dec 1, 2006 | 07:34 PM
tooslow's Avatar
tooslow
Default RE: Engine Shutdown / Oil Light
https://dodgeforum.com/m_409789/tm.htm
do this it will give you the codes no scanner needed and then post them up we might be able too help you then
Old Dec 1, 2006 | 07:56 PM
bennyhonda's Avatar
bennyhonda
Wow, didnt know that could be done without a reader. Code I get is unlisted. P0513. I googled it and it comes up under OBD III as P0513-INVALID SKIM KEY, or Incorrect Immobilizer Key?
Old Dec 2, 2006 | 01:32 AM
03neonRT's Avatar
03neonRT
What color is the key you are using? The SKIM system is a type of security system that only allows a key with the proper chip inside to start the car. So if you make a copy of the key, or if someone tries to steal it, the car wont start because the PCM isn't detecting the SKIM.
Old Dec 4, 2006 | 07:29 PM
bennyhonda's Avatar
bennyhonda
The key I used was a spare, though I disconnected the battery cable overnight and my girlfriend started it will her original key the next day with no luck. It still shuts down. Any ideas?
Old Dec 4, 2006 | 08:38 PM
04 mo neon's Avatar
04 mo neon
Electrical problem with the key chip in the car's ecu, tha's what its gotta be
Old Dec 4, 2006 | 09:30 PM
bennyhonda's Avatar
bennyhonda
If that is indeed the problem, is there a way to reset the ECU? Would a new key from Dodge help? We dont have the money to tow it anywhere at the moment. Thank you,
B
Old Dec 4, 2006 | 10:11 PM
LowSlowNeon's Avatar
LowSlowNeon
Reset should clear all the codes except for the one saying the battery has been disconnected within the last 50 cycles. I don't know if your key will work or not. Probably will have to get a new key. New keys are somewhere in the neighborhood of 100 dollars I believe...not for sure cause I haven't had to get a new key before.
