CRACKED EXHAUST MANIFOLD & CLOGGED CAT
Old Dec 6, 2006 | 11:33 PM
2kdgneon's Avatar
2kdgneon
Default CRACKED EXHAUST MANIFOLD & CLOGGED CAT
MY 2000 DODGE NEON HAS A CRACK IN THE EXHAUST MANIFOLD AND THE PRIMARY CATALATIC CONVERTER IS CLOGGED. I TOOK MY CAR TO A SHOP TO HAVE IT LOOKED AT BECAUSE IT WAS LAGGING POWER. IT WOULDNT GO OVER 30 MPH. THE MECHANIC TOLD ME THAT WAS THE PROBLEM. I AM GOING TO ATTEMPT TO FIX IT MYSELF. DOES ANYONE HAVE ANY SUGGESTIONS BEFORE I DO THIS? AND DOES ANYONE KNOW WHERE I CAN BUY A EXHAUST MANIFOLD AND A CAT?
Old Dec 6, 2006 | 11:38 PM
fullbuilt's Avatar
fullbuilt
Default RE: CRACKED EXHAUST MANIFOLD & CLOGGED CAT
what kind of money you lookin to spend.
Old Dec 7, 2006 | 12:04 AM
spikeymikey87's Avatar
spikeymikey87
dont force the bolts out. some in the exhaust manifold are spline and cant be turned. take nut off first and kroil is your friend. also make sure its cold duh
Old Dec 7, 2006 | 02:35 AM
2kdgneon's Avatar
2kdgneon
I GOT EVERYTHING OFF. THE EXHAUST MANIFOLD, AND THE PIPE WITH THE CAT ON IT. THE CAT THAT IS WELDED TO THE MANIFOLD, IS BLOWN UP ON THE INSIDE WHICH MESSED UP THE OTHER CAT SO NOW I HAVE TO BUY TWO. DOES THE MANIFOLD COME WITH THE CAT?
Old Dec 7, 2006 | 02:45 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
no, the exhaust manifold is seperate, i have one for sail if you are interested, i have a pacesetter header and a stock manifold, let me know if you are interested
