Vague Steering - 02 Neon R/T
Old Dec 10, 2006 | 05:52 PM
02_Neon_RT's Avatar
02_Neon_RT
Default Vague Steering - 02 Neon R/T
My Neon has vague steering and seems to wander across the road slightly. The last service said there are some splitting wishbone rubbers - would changing these solve the problem?
How difficult is this job?
What are the BEST new rubbers to replace tham with? Is it worth buying stiff ones from a tuning shop ($120 a set) or originals from Chrysler dealer? My Neon has done only 34,000 miles.
Many thanks
Old Dec 10, 2006 | 09:32 PM
ewetho's Avatar
ewetho
Default RE: Vague Steering - 02 Neon R/T
If your steering seems vague from what it used to be and you bushings are deteriorating then that would be a good place to start. Also make sure the rest of you suspension is up to snuff with no play in any of the parts. It can also just be a sign of too much toe out. Say you or someone smacked a curb and knocked out toe. Also check you rack & Pinion mounting making sure it is tight.
