Ground Wires
Old Dec 22, 2006 | 04:35 AM
moobit's Avatar
moobit
Default Ground Wires
I dont really have enough electrical knowledge to know about this, which is why i ask this here. What exactly do they do and are they worth buying? If so does anybody know of a good set or where to get a set? thanks.
Old Dec 22, 2006 | 05:00 AM
04 mo neon's Avatar
04 mo neon
Default RE: Ground Wires
Are u talking about audio or what?
Old Dec 22, 2006 | 12:46 PM
Ix Elit3 xI's Avatar
Ix Elit3 xI
I think he is talking about these....
http://www.eautoworks.com/html/ape-a...ire~System.htm
I googled them, not sure what they do though, talks about idle and driveability
Old Dec 22, 2006 | 04:39 PM
jBoRiCuA's Avatar
jBoRiCuA
Yeah, is it for audio?? If it is, just get a kicker kit. It goes from the amp to any metal piece in your car.
http://www.hookedontronics.com/sales...er_05+PKD4.htm
I could get something like that for $30 off my circuit city discount :-P
Old Dec 22, 2006 | 05:03 PM
04 mo neon's Avatar
04 mo neon
Yeah you need it for the amp and you have to have it for it to work I think. What I've seen done is it bolted to on of the seat bolts, bolts under the cup holders, pretty much anywhere that it connects with the frame of the car is a good place to connect the ground wire.
Old Dec 22, 2006 | 07:16 PM
fullbuilt's Avatar
fullbuilt
thats not an audio kit, well it could be if you want. but its to upgrade your grouding system for your motor and pcm
Old Dec 22, 2006 | 07:20 PM
Pablodragon's Avatar
Pablodragon
I thought there was post a while ago about a "hyper-ground" system.. had nothing to do with audio.. was actually claiming a performance boost for the engine by adding "more and higher quality grond connections" [sm=confused06.gif]
Old Dec 23, 2006 | 09:19 AM
moobit's Avatar
moobit
Im not talking about audio, sorry about the confusion. Im actually trying to find out about the ones fullbuilt mentioned, supposidely stabilizing voltage and what not. I guess it would be something like this...
http://store.racinglab.com/hygrsyfordo92.html
Old Dec 23, 2006 | 11:15 AM
fullbuilt's Avatar
fullbuilt
it will help alittle, but its best when using an upgraded ignition system.
