first mods to a 04 neon sxt
Old Dec 24, 2006 | 04:17 PM
havokneon's Avatar
havokneon
Default first mods to a 04 neon sxt
im needing help on figuring out what i should put first in my neon to boost the hp. And if anyone out there know a good site to find goods prices on mod parts .. please help!!!!!!
Old Dec 24, 2006 | 04:39 PM
ewetho's Avatar
ewetho
Default RE: first mods to a 04 neon sxt
Unfortunately we both have the NGC computer. You will not build much extra HP with it. Probably the best things you can do is underdrive pulley and exhaust and intake. Should be a couple. If not enough you probably need cams and then on to megasquirt.
Old Dec 24, 2006 | 04:44 PM
havokneon's Avatar
havokneon
whats the ngc comp? and what does it have to do with hp? and what underdrive pulley and exhaust and intake should i get?
Old Dec 24, 2006 | 06:14 PM
spikeymikey87's Avatar
spikeymikey87
ngc stands for next generation computer. its on all 03+ dodge cars and to make a long story short it forces your car to run like it did out of the factory which means that you dont get too much hp from mods. best site for stuff is modernperformance.com and howellautomotive.com is ok too but ive heard bad things about their shipping times
Old Dec 24, 2006 | 06:39 PM
AirWolf's Avatar
AirWolf
Other than intake and exhaust and underdrive pully Id say better plugs and wires also.
Old Dec 24, 2006 | 07:22 PM
03neonRT's Avatar
03neonRT
Oh boy here we go again with the NGC crap...while the NGC does attempt to compensatefor the increase in HP by changing your A/F ratios it can only do so much...the actual HP being "robbed" from your modification is minimal and you will see almost the same gains as if you put those mods onto a 00-02 Neon. There is ZERO evidence to support ther NGC can literally take away horsepower from the mods you add-on, it can reduce the mods affect but only to a cetain extent.
Some first mods you should do are: Cold Air Intake (K&N Typhoon), Lightweight Underdrive Pulley (Unorthodox Racing), Short Throw Shifter, and maybe some front/rear strut tower bars and lowering springs for some suspension mods. Othe mods you can do are swaps fromth e magnum engine, such as the cam, intake manifold, exhaust manifold, and the head.
Old Dec 24, 2006 | 10:21 PM
goldberg's Avatar
goldberg
http://www.modernperformance.com/dcx/neonstag.shtml
same as SOHC 1995-1999 Neons Just different Parts....
Old Dec 24, 2006 | 10:30 PM
havokneon's Avatar
havokneon
really?
Old Dec 25, 2006 | 07:38 PM
03neonRT's Avatar
03neonRT
No, its not 100% compatability but most things that work on the 1st gen will work on the 2nd gens...
Old Dec 27, 2006 | 12:38 AM
havokneon's Avatar
havokneon
does anyone have any more ideas? how bout cheap ones?want first mods the best choice . i dont want to mess this up!!!plz more ideas
