Check Engine Light Blinks?
Old Jan 6, 2007 | 07:05 PM
tyler819's Avatar
tyler819
Default Check Engine Light Blinks?
Sometimes wen i take my car above 5000rpm the CEL will blink like 3 or four times and then it will go off. I have no cat and got a simulator and my CEL is always off unless wen i bring it into higher rpm's the light will blink sometimes. Does anyone know wat it could mean?
Old Jan 6, 2007 | 07:13 PM
03neonRT's Avatar
03neonRT
Default RE: Check Engine Light Blinks?
Its the UDP causing it...in the 2002 model year they bumped up the misfire monitor so once you hit 5k it thinks your misfiring even though you arent. So theres nothing wrong, and theres nothing you can do to fix it either...
Old Jan 6, 2007 | 08:43 PM
tyler819's Avatar
tyler819
ok good because it runs perfectly so i didnt think it meant much.
