rear mount turbo
Old Jan 7, 2007 | 06:14 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: rear mount turbo
i was just thinking about the twin turbo idea, and was wondering if i would be better off running a 100 wet shot of nitrous instead??? i really love turbos and the way they perform, but the engine bay i do not think is going to hold, two, and if i do it, it will be twin turboed, so with that being said what can i see performance gains to the wheels with a twin turbo setup, running maybe ten psi???? that is about 100 hp gain correct?????? if that is the case and the turbos will not fit under the hood, i can build the car to start with a hundredshot and then put the turbos on at a later date??? but if i am giong to get more hp out of the twin turbo setup, then i will do that first, and wait on the bottle.......
Old Jan 7, 2007 | 07:09 PM
fullbuilt's Avatar
fullbuilt
depends, are you doing 10 psi each or 5psi each, the 302 setup with 6 psi each gains 170 whp
Old Jan 8, 2007 | 12:06 AM
dtjackten's Avatar
dtjackten
ok, so it is a big difference, i wanted 10 each, so that would be about 200 whp, so a BIG difference when i go for the twin turbo, than a 100 shot.....keep the info coming at that rate it will be a 500hp car easiely, it will be something to contend with at least...that is what i am looking for....thanks for the help any other info would be greatly appreicated!!!!!!!!!
