2004 dodge neon stuck at 4000rpm
what do you mean it is idling there. if it is idling there constantly yo have huge problem and shouldnt ever drive that car until its fixed im assuming you mean you cant rev past 4000 in park or neutral which is completely normal and cant be helped
I say you should tow it to a dealership to get it looked at. Under warrantee. THAT or you have to start doing a lot of work!
The only things I see is the MAF sensor or the TPS
I do, like LowSlow lean towards the TPS.
Trending Topics
just listen for load hiss what that is how I normally find my leaks.
you might want too check if throttle cable is stuck at t/b.
How can bad tps cause this? Don't understand how it could up the cars idle?
It could be the iac motorbut I would check the cheap first.
if its a vac leek you wouldnt make it past 4000 but idle would be normal chepest check is to ckeck your throttle spring to make sure it is retuning to idle or is not blocked by anything. then make sure your throttle cabble is able to retract and not jammed
