rims?
Old Jan 23, 2007 | 07:36 PM
Andpto's Avatar
Andpto
Default rims?
Will these rims fit on a 2000plymouth neon? I found them on Ebay.They areAdam Saruwatari Tuning Series wheels AKA A&L Racing Wheels made Enkei Size 17x7JBolt Pattern 5x114.3 Retail new for about $250 each. They're at 99 dollars now but i dont kno how much they would go up to. They include used bridgestone wheels.I need some new rims for my car, im running stock rims( and they are stratch up
[IMG]local://upfiles/53221/28AAAB7476B14946B9BB549A4C6DA3FC.jpg[/IMG]
[IMG]local://upfiles/53221/9839014B0F6F4A76B3C6CE4D967CBF68.jpg[/IMG]
Old Jan 23, 2007 | 08:50 PM
Pablodragon's Avatar
Pablodragon
Default RE: rims?
I would say no because of the bolt pattern...I have always heard here, that the Neon bolt pattern is 5x100
but maybe someone with a little more expertise can help....
Old Jan 23, 2007 | 09:13 PM
jBoRiCuA's Avatar
jBoRiCuA
Default RE: rims?
Those wheels look both 5x100 and 5x114.3. Tell the seller to give you a part number to look them up. But yea, bolt pattern is 5x100 but those wheels have 10 holes so just tell him to give you the part number and look them up.
blk94z28's Avatar
blk94z28
Default RE: rims?
they might fit because theyre a dual lug pattern, do you know what vehicle they came off of? you can look on enkie's web site and maybe find out there. Im pretty sure the neons lug patter is 5-100 also.
Old Jan 23, 2007 | 09:31 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: rims?
neon bolt pattern is 5x100 i wouldnt try it
Old Jan 23, 2007 | 09:53 PM
jBoRiCuA's Avatar
jBoRiCuA
Default RE: rims?
Those rims aren't just 5x114.3..dont you see the holes.
Old Jan 24, 2007 | 06:18 PM
Pablodragon
Default RE: rims?
ORIGINAL: jBoRiCuA
I see it... 5 of the holes are further out, a wider pattern, and the opposite holes (every other one) has a tighter pattern..could be 5x100
Old Jan 24, 2007 | 09:25 PM
spikeymikey87
Default RE: rims?
yes i do see the other holes. if it says 5x114.3 then im assuming it is. if you want take a ruler and measure 2 holes across from eachother i believe it should be 4 inches
