Changing a battery....
Old Jan 26, 2007 | 06:10 PM
Acrfanatic's Avatar
Acrfanatic
Default Changing a battery....
Since i am really stupid when it comes to cars....can anyone walk me through how to change a battery
Old Jan 26, 2007 | 06:52 PM
NHARINTON's Avatar
NHARINTON
Default RE: Changing a battery....
Get a #10 deep socket. Disconnect the battery terminals. Negative first... just dont let it hit anything metal. then pull the old battery out. set the new one in. Connect the negative terminal, then the positive terminal. and BAM your done!!!
Oh one more thing, since you have it off you might wat to grab a wire brush and clean the terminal clamps just to make sure they are good and clean!!
Old Jan 26, 2007 | 08:49 PM
03neonRT's Avatar
03neonRT
^ ^Also, on mine the battery is "bolted" down to the tray, and I have the battery warmer which you have to disconnect also...there is a bolt behind the battery (14mm i think?) that you loosen which will make the bracket less tense thats holding the battery in place, then you just pull the battery up and out.
Old Jan 26, 2007 | 09:16 PM
fullbuilt's Avatar
fullbuilt
step one go to autozone step two buy baterry step three let them do the rest plus that way you dont have to bother with a core charge
Old Jan 27, 2007 | 01:22 AM
neisg1's Avatar
neisg1
It’s also a good idea to coat the battery terminals (after cleaning) with a dielectric grease, it seals out oxygen and acid residue, thus preventing corrosion. It’s available at most auto supply stores. A good substitute is Vaseline.
Old Jan 27, 2007 | 01:31 AM
ewetho's Avatar
ewetho
Ah the reason for negative first is if you do hit something metal you don't hurt anything. Once the Negative is off then if you hit something with the wrench NO BIG DEAL!!!
Old Jul 14, 2007 | 11:30 AM
AmysNeon's Avatar
AmysNeon
Mine has a soft cover over the battery. How is it removed?
Old Jul 14, 2007 | 02:36 PM
03neonRT's Avatar
03neonRT
The cover is a battery "warmer"...there should be a plug on the back that you just have to pull out then the cover will lift right out.
Old Jul 15, 2007 | 12:30 AM
andfeng's Avatar
andfeng
whats the battery warmer for casn we cut it and is it usefull????
Old Jul 15, 2007 | 03:16 AM
03neonRT's Avatar
03neonRT
The battery warmer does a few things. One, it helps protect the battery from high temperatures under the hood. Second, it helps "warm" the battery slightly because a cold battery has a higher internal resistance as opposed to a warm battery. Third, the battery temp sensor thats plugged into the back of the warmer is used to monitor the battery temperature by the PCM so it can adjust voltage, battery charging rate, etc...
