Electrical Problem with 2002 Neon
Old Feb 8, 2007 | 03:56 PM
NJNeonGirl658's Avatar
NJNeonGirl658
Default Electrical Problem with 2002 Neon
Hi Eveyone!
Need your advice/help. New to Dodge Forum.
I hit a deer last May (by accident!!). Over $5,000. worth of damage. Besides body work, needed new power steering pump.
Dec. I started having the "electrical" problems some of you have already written in. Wipers coming on for no reason which also affects the speedometer which goes "haywire" and now the door chime is coming on along with everything else.
My dealer has already replaced the speed, sensor, multi-function switch, wiring harness and transmission control module. I picked up the car this Mon. and Tues. morning I was back at the dealer. Car going back in on 2/19. The boys at the service center said that once they put these last 3 parts in, they still didn't know if it would be repaired. Any advice/suggestions? Please Help, I would REALLY appreciate it!
Thank you!
NJNeonGirl658
P.S. This is my 2nd Neon. I also had 2 Daytonas and my very first car was a Dodge Aspen. A Doge Girl through and through!
