Tire Size for my new 17" rims
Old Feb 13, 2007 | 09:58 PM
wigsthegreat's Avatar
wigsthegreat
Default Tire Size for my new 17" rims
hey i am getting a new set of enkei rims for my bday and i need to know whats the bestsize tire i should use for them on my 2001 neon...i dont have any lowering spring yet but i plan on getting them over the summer...
Old Feb 13, 2007 | 10:01 PM
djmagic's Avatar
djmagic
Default RE: Tire Size for my new 17" rims
Talk with whoever is putting them on.
Old Feb 13, 2007 | 11:40 PM
Exubus's Avatar
Exubus
If your rims are 7 or 7.5" wide, the "perfect" tire size for your Neon is:
205/40/*R17
This tire diameter is basically dead-on to the stock tire diameter. The width is about the perfect size for a 17" rim, and one of the widest that you can fit on the Neon. Make sure your rims aren't any wider than 7.5" wide, and make sure the offset is at least 35mm or they may not fit on your car without rubbing on something.
Old Feb 14, 2007 | 01:28 AM
qnr69's Avatar
qnr69
nope the best tire size is 215 40 thats wats on mine their just perfect
Old Feb 14, 2007 | 04:59 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
205s will fit just fine on a 6" rim (stock SRT rims). so if they are 7 or 7.5" rims, you can go even wider, only issue you have have is with a stock suspension and rubbing. 205/40s are pretty safe though if you want to stay conservative on width
