interior lights
Old Feb 20, 2007 | 08:01 PM
twk62390's Avatar
twk62390
Default interior lights
so last night i bought 20 led lights to out inside my car. i want them in the ac vents and floor board. for those of you who has done this i was wondering how many you put in each vent to light it up enough. and what did you use for the power source......the headlights? i just wanna do this right the first time and not have wires and bulbs showing like rice. thanks
Old Feb 20, 2007 | 10:00 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: interior lights
well in my opinion thats super rice, but id put one in a vent and use something that you dont use often as the power for it, unless you are using a switch. if thats the case put it on the headlight if its only gonna b on a night or cig lighter or wipers for all day
Old Feb 24, 2007 | 05:12 PM
Pablodragon's Avatar
Pablodragon
just a little heads up...
I know, alot of the stuff I try to post here and ask opinions on usually always gets a "rice" comment, but it's just personel preference....keep in mind I am married to a Filipina and have aton of Filipino friends, and yes..we have a rice cooker that's on pretty much 24/7..[sm=bustedsign.gif]
but to the point, I noticed that my local Meijers store has the accents lighting like LEDs and neon and strobes marked way down, maybe just cuz I'm in a snow-type state or area...example...single LEDs, like 4 of them for around 3 to 5 bucks...headlight strobes 6 dollars, ....they are marked 50%off but when u scan tem, they come up even lower
Old Feb 24, 2007 | 08:30 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
i would just wire them on a switch. so you can have them on with the car off, and turn them off whendriving.
Old Feb 25, 2007 | 12:21 AM
twk62390's Avatar
twk62390
thanks.....i think a switch is the best thing too
Old Feb 25, 2007 | 02:17 AM
natiku's Avatar
natiku
ORIGINAL: twk62390
that white thing in the lighter holeis my switch for my lights
http://img.photobucket.com/albums/v2...u/IMGA0028.gif
Old Feb 25, 2007 | 02:48 AM
twk62390's Avatar
twk62390
what kinda switch is that to go in there. i have a little flip switch i was gonna mount on the dash or in the console. and also how many leds did it take to light your vents up good?
Old Feb 25, 2007 | 03:37 AM
natiku's Avatar
natiku
only took 1LEDper vent, The switch is a small push switch which came with the long tubed neons.
one thing i like about my setup is that it takes less then10 mins to remove the neons and wires, without leaving holes in the interior.
Old Feb 25, 2007 | 03:51 AM
twk62390's Avatar
twk62390
thanks. also. i kno how to get the vents off and all but im guessing you just stuck your arm though the side of the dash to grab the wires that are connected to the lights
Old Feb 25, 2007 | 04:52 AM
wanabesrt's Avatar
wanabesrt
will u guyz be cookin white rice or yellow?
