TOKICO
Old Feb 22, 2007 | 08:14 PM
03neonRT's Avatar
03neonRT
Default RE: TOKICO
Just make sure the vice-grips arent on extremely tight because those sockets tend to bend if you put too much pressure on them.
Old Jun 21, 2007 | 03:00 AM
2003SXTneon's Avatar
2003SXTneon
Default RE: TOKICO
with the tokico springs howmuch will it lower the car?i checked the website and couldnt find anywhere that said. let me know how the install goes and how the ride is. looks like something i might be interested in getting.
Old Jun 21, 2007 | 03:14 AM
GrApHite03's Avatar
GrApHite03
Default RE: TOKICO
ORIGINAL: 2003SXTneon
I checked the site and it doesn't mention any brand of springs in particular. It doesn't seem as if tey are lowering springs. The kits that do come with lowered springs referense the kind of spring.
k3v
Old Jun 21, 2007 | 03:19 AM
GrApHite03's Avatar
GrApHite03
Default RE: TOKICO
HPK 297
ok, i'm wrong.... i re-read.
k3v
Old Jun 21, 2007 | 05:22 AM
03neonRT's Avatar
03neonRT
Default RE: TOKICO
From what I've heard the Tokico springs will lower 1.4" all around with the Blues...I think Spikey has them installed with his Blues though.
Old Jun 21, 2007 | 10:46 PM
neon 05's Avatar
neon 05
Default RE: TOKICO
it would take you like two hrs depends if you take your time!!
Old Jun 22, 2007 | 10:33 AM
NHARINTON's Avatar
NHARINTON
Default RE: TOKICO
I got what looks like 2' up front and 2.5 in back. Handles like a dream with my 17's. Took me about 2.5-3hrs.
The springs are made by Tokico, same as the struts.
Old Jun 22, 2007 | 03:48 PM
neon03se's Avatar
neon03se
Default RE: TOKICO
how did you use that tip with the socket that RT gave you harinton?
Old Jun 22, 2007 | 04:21 PM
neon 05's Avatar
neon 05
Default RE: TOKICO
man i try the socket and a breaker bar i was just spining the nut...
harinton thats the tokico springs and the struts together gave you that drop or you have a hidden secret!?
Old Jun 22, 2007 | 05:21 PM
NHARINTON's Avatar
NHARINTON
Default RE: TOKICO
I TOOK A SPARK PLUG SOCKET AND DRILLED OUT THE HOLE THRU A LITTLE IT AND THEN USED A 1/8' SOCKET AND EXTENSION THRU THE MIDDLE. A PAIR OF VICE GRIPS A BAM IT WORKED GREAT.
AND NO THATS HOW MUCH DROP I GOT WITH IT!!
***sorry about the caps!!***
