TOKICO
Old Feb 21, 2007 | 08:12 PM
NHARINTON's Avatar
NHARINTON
Default TOKICO
Well i just ordered the tokico "performance package" from a place called ASI motorsports in San Diego. Comes with shocks springs and the camber ajusters. I get to pick it up tomarrow and take a wild guess how much i paid?????? $$371.76 including shipping!!!!! And i belive the will ship it anywere!!!
Does anyone know how long the install takes?
Old Feb 21, 2007 | 08:20 PM
03neonRT's Avatar
03neonRT
Default RE: TOKICO
I assume by "camber adjusters" it mean camber adjusting bolts? The install shouldnt take that long...maybe four hours start to finish. Does this place have a website for this kit (so I can add it to the Performace FAQ) ?
Old Feb 21, 2007 | 08:28 PM
NHARINTON's Avatar
NHARINTON
Default RE: TOKICO
yeah thier website is:
www.shox.com
and the kit is called "Tokico advanced handling kit" they have a ton of kits from just a sway bar, to just springs to full coilover kits. and they are the cheapist i have seen!!!
Old Feb 22, 2007 | 06:23 AM
NHARINTON's Avatar
NHARINTON
Default RE: TOKICO
anything i should know about the install?? Tricks tips???
Old Feb 22, 2007 | 04:29 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: TOKICO
air tools
Old Feb 22, 2007 | 05:33 PM
NHARINTON's Avatar
NHARINTON
Default RE: TOKICO
damn that i dont have....
Old Feb 22, 2007 | 05:40 PM
spikeymikey87
Default RE: TOKICO
then its going to be a big pain in the *** to take off the bushings and whatnot off of the stock struts to reuse. youll also need a spring compressor
Old Feb 22, 2007 | 05:45 PM
NHARINTON's Avatar
NHARINTON
Default RE: TOKICO
well the spring compressor is easy, and what bushing do i reuse? they kit i got is "assembled and complete" from tokico. I was figuring it is just... pull the old one and put the new one in?
Old Feb 22, 2007 | 06:30 PM
03neonRT's Avatar
03neonRT
Default RE: TOKICO
You have to use the top hats from the original struts...you dont really need air tools, but they do come in handy. Make sure you have a spring compressor and a way to get the center nut off. I made my own tool with vice grips, a tractor spark plug socket, and a 10mm socket with extension. The spark plug socket will turn the nut while the 10mm socket whill keep the strut shaft from turning.
Heres a pic...if you've looked at the top of the strut you'll understand what I mean.
[IMG]local://upfiles/24091/D179AB6A02134FCAA5C2BCCF8153314B.jpg[/IMG]
Old Feb 22, 2007 | 08:09 PM
NHARINTON's Avatar
NHARINTON
Default RE: TOKICO
awsome, ill do the same thing!!
