Pt cruiser engine in a neon
Old Feb 24, 2007 | 03:48 PM
djmagic's Avatar
djmagic
Default RE: Pt cruiser engine in a neon
I like the SRT because it looks better. It has the SRT-4 piece on it. Thx for the help guys, just thought it would be hard finding the pt turbo tranny.
Old Aug 26, 2022 | 05:24 PM
telnaw1's Avatar
telnaw1
Originally Posted by 03neonRT
As far as I know the N/A and turbo PT Cruisers use the same automatic transmission. As for parts you'll need, the parts list will be the same between the N/A and turbo 2.4, you wold substitute things like the air intake and exhaust manifolds (among other things). You'll need the lower motor mounts, the upper mounts are the same between the 2.0 and 2.4 IIRC...
I have a question what if the transmission in the pt is automatic n the trans in the neon is standard what needs to be changed to swap just motors?
