This Place is DEAD!
Old Feb 28, 2007 | 02:50 AM
spikeymikey87's Avatar
spikeymikey87
Default RE: This Place is DEAD!
niceness what kind of paint did you use to paint the inside of the housing black? hope its a high heat kind or else it will be messy
Old Feb 28, 2007 | 02:53 AM
03neonRT's Avatar
03neonRT
High temp engine paint or something like that I would assume...
Old Feb 28, 2007 | 02:57 AM
03neonRT's Avatar
03neonRT
Well I'm a few months away from hitting 60k on the odometer...so I've decided to change my timing belt and do a complete top end and lower end gasket overhaul. The best part is my parents said they might get me a my Comp 400 and AEM gear (the head will be off so install will be a snap) that I've been wanting but havent been able to afford...plus I plan on taking out the middle layer of the MLS head gasket which should give me a point or so increase in compression...thinking about adding a crank sccraper and windage tray to my oil pan but I'm not sure yet...
Old Feb 28, 2007 | 02:59 AM
spikeymikey87
yea i think i might need to get the crank scraper and windage tray when i do the build. what do they exactly do and what are some prices?
Old Feb 28, 2007 | 03:02 AM
03neonRT's Avatar
03neonRT
The windage tray keeps the oil from moving around during turns and heavy acceleration...the crank scaper keeps the oil off the crank which reduces the cranks mass (a little extra performance)...which by keeping the excess oil off the crank means more oil in the pan, which is more oil for lubrication...which is good. Crank scrapers are usually around $100 and the windage tray varies but usually around $150-$200 i think. I'd love to get my hands on the Moroso oil pan though...
Old Feb 28, 2007 | 03:06 AM
spikeymikey87
where do i get something like that i know modern has a crank scraper for like 140. but id rather cheaper and is a windage tray just a new oil pan?
Old Feb 28, 2007 | 03:17 AM
03neonRT's Avatar
03neonRT
The windage tray is like an insert that is placed inside the oil pan...you get a windage tray and crank scaper for $300 or just the crank scaper for $70.00 here --> http://www.crank-scrapers.com/prod01.html
Old Feb 28, 2007 | 03:20 AM
spikeymikey87
is it something that i can just bolt on later, or is extensive work and i will need the engine apart to do it easier?
Old Feb 28, 2007 | 03:32 AM
03neonRT's Avatar
03neonRT
All you have to do is drain the oil and drop the pan as far as i know...
Old Feb 28, 2007 | 03:33 AM
spikeymikey87
ok then thats one less thing that i need to buy for this build and it can go on later on
