Odometer Says "No Bus".....
Old Mar 3, 2007 | 10:07 PM
Kornkid's Avatar
Kornkid
Default Odometer Says "No Bus".....
So lets just say that my little 2000 dodge neon is intellgent and has come to the realization that it is infact not a bus. but none the less I would like to fix this problem because with it my airbag light comes on and also my check engine light. wether they are related or not they all came on at the same time but I wasmore nieve at the time so its quiet possible it was just relatively the same time I was just not paying attention to instrument panel.
Old Mar 4, 2007 | 03:27 AM
crracerus's Avatar
crracerus
Default RE: Odometer Says "No Bus".....
lmfao!!!
Old Mar 5, 2007 | 11:31 PM
NHARINTON's Avatar
NHARINTON
It is the fuse under your hood, that has the little puller on it. It is called a "bus" fuse!!! Just had it happem to me!
Old Aug 11, 2014 | 09:40 AM
ledfoot1's Avatar
ledfoot1
Default " no bus light"
So when u replaced it did tha light come off? Cus my fuse is good and light is still on, it happened right after they installed a stereo in it.
