changing parking brake and shift knob
Old Mar 12, 2007 | 11:27 PM
gm830's Avatar
gm830
Default changing parking brake and shift ****
has anyone changed the parking brake handles and shift ***** in their neons? i have an automatic. i saw a screw on the shift **** which i assume i unscrew to change but i'm not sure how i would change the parking brake handle.
Old Mar 13, 2007 | 03:03 AM
lblackneon's Avatar
lblackneon
Default RE: changing parking brake and shift ****
I've changed my shift **** on my stick shift. It's pretty simple. I couldn't tell u where which screws are on your auto though.
As far as the parking brake, I haven't seen any brake handles for the Neon. If there are, let me know. I was just checking a Sparco brake handle out today to go with my Sparco shift ****. It's funny that this post happened when I was looking into it. The Sparco brake handle wont work with the one on the Neon though.[&o]
Old Mar 17, 2007 | 05:18 PM
blocks885's Avatar
blocks885
Could a moderator answer this or point in the right direction if they know how to replace the shift **** on an automatic? Thanks.
Old Mar 18, 2007 | 05:18 PM
blocks885's Avatar
blocks885
Old Mar 18, 2007 | 06:52 PM
gm830's Avatar
gm830
well i've seen the screw on the side of the **** for the automatic so i don't think that would be complicated, i'm more concerned with changing the parking brake if it's possible
Old Mar 18, 2007 | 07:20 PM
03neonRT's Avatar
03neonRT
To replace the automatic shift **** all you have to do is loosen the allen key screw in front of the shift ****...it should slide right off. I've heard that any Dodge/Chrysler/Jeep console shifter **** will bolt right up to ours (so if you wanted a leather one). Universal aftermarket ones will also work, and should come with adaptors if they dont fir right...some of the aftermarket ones dont stay tight though...
As for the parking brake, its one molded piece of plastic, and I havent seen any real replacements...tey make covers, but no entire replacement because of the size/shape/difficulty of doing so...
Old Mar 18, 2007 | 09:48 PM
spikeymikey87's Avatar
spikeymikey87
yea there is an allen key to take off the shifter, but i would suggest keeping it because all of the aftermarket ones just dont look right, dont fit right, or just break. the parking brake is one piece that i cant see a way of taking it off
Old Mar 18, 2007 | 10:57 PM
AirWolf's Avatar
AirWolf
I got mine replaced right away and found a very cool one off of ebay for my auto sxt and just got a chrome /cf cover for my e brake and my gearshift is chrome and cf also. Not very hard to replace for auto or stick.
Old Mar 18, 2007 | 11:38 PM
gm830's Avatar
gm830
what brand is the parking brake cover that you got? most of the ones i've seen don't look like they'd fit because of the shape of the parking brake with the hills, etc
Old Mar 18, 2007 | 11:45 PM
AirWolf's Avatar
AirWolf
I got mine off of ebay pilot is the brand it just sticks on was like 10 bucks shipped. Dont see them much on ebay though I was just lucky enough to find one to match pretty well with my shift ****.
