New Guy
Old Mar 14, 2007 | 08:01 PM
Biged83's Avatar
Biged83
Default New Guy
Hey all my name is Ed. I am new to the whole dodge community. i used to have a 98 kia sephia which i loved but it was time for new (newer). So i purchesed a 04 neon SXT 5 speed fully loaded. So i am new to this thread. i got a few questions. is there anything for me to watch out for? and how is there a how to on a cold air intake installation posted? because i was looking and im all sorts of lost on how to do it or atleast can i remove the air box and put in just a cone filter for now?
Old Mar 14, 2007 | 09:21 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: New Guy
yea theres howtos in teh stickies. welcome to the forum and the whole dodge community
Old Mar 14, 2007 | 09:27 PM
03neonRT's Avatar
03neonRT
Default RE: New Guy
I just added a new how-to for a CAI install in the sticky...and welcome to the forum!!
Old Mar 14, 2007 | 09:31 PM
lblackneon's Avatar
lblackneon
Default RE: New Guy
Welcome to the forum. There isn't really anything to look out for. Just make sure you take care of the car and put the right fluids in the car. Have fun with it.
Biged83's Avatar
Biged83
Default RE: New Guy
maybe im missing something i cant find the how-to's
Old Mar 14, 2007 | 09:36 PM
03neonRT's Avatar
03neonRT
Default RE: New Guy
https://dodgeforum.com/m_665840/mpag.../tm.htm#665842
Below the build-up guide there are part reviews, install ratings, places to buy, and install instructions...
These are te installl isntructions I just added...
Installation Instructions:
1.) Disconnect the negative battery cable.
2.) Remove the air temperature sensor from the stock intake tube.
3.) Remove the wire loom from the retaining clips on the side of the stock air box.
4.) Loosen and remove the five airbox retaining bolts then remove the airbox lid.
5.) Remove stock air filter.
6.) Remove intake tube from fender well.
7.) Remove the four throttle body retaining bolts from airbox (these bolts will be re-used).
8.) Remove the crankcase vent hose from the air box.
9.) Remove the bolt and nut that secures the airbox to the vehicle then remove the airbox (this bolt and nut will be reused).
10.) Break lug nuts loose, then jack up the drivers side of the vehicle (remember to support with jackstands).
11.) Using a T-20 wrench, remove the two screws that retain the inner fender valance to the fender. Then remove the two push pins and move fender valance away to allow access into the fender well.
12.) Remove the two bolts that retain the resonator to the fender well then remove the resonator.
13.) Remove thebattery tray mounting bolt (this will be reused).
14.) Using the four bolts that were removed in Step #7, secure the two provided throttle body brackets to the throttle body.
15.) Using the battery tray mounting bolt that was removed in step #13, mount the throttle body bracket to the battery tray.
16.) Using the stock bolt removed instep #9, secure the throttle body bracket to the stock airbox mount.
17.) Install the supplied silicone hose and hose clamps to the throttle body and tighten throttle body hose clamp. Then, install the supplied edge trim to the resonator fender well hole. Finaly, install the larger grommet into the intake tube bracket and the smaller grommet into the intake tube.
18.) Slide the intake tube down the resonator hole then insert the other end into the throttle body silicone clamp.
19.) Align the intake tube braket to the stock airbox mount. Using the supplied nut, tighten the intake bracket to the stock mounting stud.
20.) Install the air temp sensor into the rubber grommet on the intake tube.
21.) Using the supplied silicone hose, attach one end to the intake tube and the other end to the crankcase vent tube.
22.) Install the hose calmp onto the air filter and attach to the intake tube inside the fender well.
*Note* Make sure everything is tight!
23.) Remount inner fender well valance, tire, and reconnect negative batter cable in reverse order.
**These instructions were writen for the K&N Typhoon Cold Air Intake and may vary depending on CAI brand**
Old Mar 14, 2007 | 09:42 PM
Biged83's Avatar
Biged83
Default RE: New Guy
well hey that was easy. is there away to just install the cone filter on there with out the cai. im kinda broke after buying this car. i will be posting some pics up once i get some time off from work.
Old Mar 14, 2007 | 09:45 PM
spikeymikey87
Default RE: New Guy
yea but you need to fab up some kind of bracked to hold the throttle body up because it needs some support. adds a really great sound to it
Old Mar 14, 2007 | 09:46 PM
Biged83's Avatar
Biged83
Default RE: New Guy
i had to do the same with my sephia to hold up the mas. i was reading that if you pop the top of the intake box and put in a cone filter it does the same thing. im just going for sound as of right now. im not to concerned with power added to it.
Old Mar 15, 2007 | 04:30 PM
gabo's Avatar
gabo
Default RE: New Guy
are u theguy that bought the pokemon car?
