Question about a PCM (not the Megasquirt)
Old Mar 20, 2007 | 10:34 PM
snare_samn's Avatar
snare_samn
Default Question about a PCM (not the Megasquirt)
I read somewhere on this site that the rev limiter on2000 Neon's is 6750 rpm's but can be raised to 8000 with an aftermarket PCM that will also get rid of the speed limiter. Can anyone give me the name of one of these or where I can get one? (I don't want a megasquirt PCM, they sound WAY too difficult for me)
Old Mar 21, 2007 | 12:04 AM
Andpto's Avatar
Andpto
Default RE: Question about a PCM (not the Megasquirt)
http://www.howellautomotive.com/inde...amp;ProdID=129
Old Mar 21, 2007 | 12:33 AM
spikeymikey87's Avatar
spikeymikey87
just a warning, the cars dont rev to 8000 for a reason. it will blow up
Old Mar 21, 2007 | 01:19 AM
lblackneon's Avatar
lblackneon
The AFX Race PCM MT has a 7800 rpm limit.
The AFX Street PCM has a 7500 fuel cut off limit.
I have the AFX Race PCM. When I first installed my pcm, I had bolt-ons with no internal engine work. I took the car out for the first time with it on and took it to about 7300-7400 rpm. The car smelled funny afterwards. I wouldn't recommend taking the car up that high unless you have internal engine work done to your engine that can handle the high rpms.
Old Mar 21, 2007 | 02:27 AM
snare_samn's Avatar
snare_samn
All I have is turbo; I guess I'll just save up for the 2.4 SRT engine first.... Thanks for the info guys, I would have blown myself up, lol.
Old Mar 21, 2007 | 02:34 PM
tooslow's Avatar
tooslow
don't run the afx with a turbo it has more spark advance so you will detonate really bad bye bye pistons
Old Mar 21, 2007 | 05:20 PM
lblackneon's Avatar
lblackneon
ORIGINAL: snare_samn
In order to run a turbo with an AFX pcm, you would need to retard the ignition timing. I called Howell some time ago and they told me that.
