bolts on/cam
Old Mar 26, 2007 | 08:12 AM
Freerider's Avatar
Freerider
Default RE: bolts on/cam
ORIGINAL: lblackneon
Are u done with your installation yet? My car takes a bit longer to start than normal.
Yea, I finished last weekend (by last weekend I mean saturday the 17th)
Mine runs pretty well. I have to admit my auto tranny sucks and it is looking like I need to re-flash my ECU from the factory becuase it seems to be acting finicky (aka a low idle even with a new ignition coil).
The car runs great otherwise.
A UDP allows your car to rev faster. Good Upgrade and probably my next bolt on. However it will probably come after some suspension mods......
A cam gear works great if you plan on taking your car to a dyno and tuning your cam timing. Other than that it is a waste of money if you don't intend to bring the car to a dyno. It would sit there and look pretty (or if you leave your belt cover on... not look like anything)
Old Mar 26, 2007 | 03:32 PM
lblackneon's Avatar
lblackneon
Your car starts up like it use to???
Old Mar 26, 2007 | 10:32 PM
2003SXTneon's Avatar
2003SXTneon
Is it recomeneded to dyno the car? to get a dyno done it's like $150, right. so what size cam does every one agree on the 10 or 12, and is any one running either?
Old Mar 26, 2007 | 11:55 PM
lblackneon's Avatar
lblackneon
I have a cam 12 and so does freerider. U don't have to go to the dyno but u go there if u want to get the most horsepower out of your car. U go to the dyno if u want to advance or retard your timing on an adjustable cam gear.
It just depends how far u want to go with the car. How far do u want to go?
Old Mar 27, 2007 | 12:29 AM
lilracingneon's Avatar
lilracingneon
Maybe youall can help me, straight stock mine was a mid 17 car. thus far i have done the exhaust, cam gear, cai, header and pipe, and tricked the IAT with a diode. after all that the car is still in the mid 17's. what gives?
Old Mar 27, 2007 | 01:01 AM
Izero's Avatar
Izero
well im betting that diode prolly isnt helping anything........
Old Mar 27, 2007 | 03:07 AM
lilracingneon
actually the diode helped a bit, it tricks the IAT into thinking that the air is colder than it is. the computer then adds more gas.
Old Mar 27, 2007 | 03:10 AM
spikeymikey87's Avatar
spikeymikey87
no the diode is doing absolutly dick. the computer works the way it wants to. no offence but ou wasted your money. i hate when people sell that crap it just pisses me off but anyway, if you want some real power to get you into the lower numbers turbo it or do a swap. check teh stickies
Old Mar 27, 2007 | 02:43 PM
lblackneon's Avatar
lblackneon
U also got a cam gear without an upgraded cam. That's a waste of money too. U wouldn't want to advance or retard timing on a stock cam. With the mods u have you probably got 10 hp. U wont feel much of that.
