engine making a tapping noise.
Old Mar 7, 2008 | 09:26 AM
  #21
nicolasl46's Avatar
nicolasl46
Default RE: engine making a tapping noise.
ORIGINAL: dtjackten
just MAKE SURE TO, have them set at the corect torque specs. that is prolly one of the most important things u can do when doing this job... and i got mine from mopar, but i worked there at the time so it was not that bad in price...... i accually have a set if u were interested, but they have been sitting around, so it may take a while for them to pump up..... if u r interested let me know.......
i honestly had mine done in about 30 min... if that, i have an impact to get the valve cover off really fast.... then just take ur time and there will be spacers between the lifters... makesure u put them back together exactly the way u pulled them off......
those lifters you have, how old are them? and how much?
Old Mar 7, 2008 | 12:16 PM
  #22
djmagic's Avatar
djmagic
now you have to stick with syntechic. You can't go back to conventional
Old Mar 7, 2008 | 01:06 PM
  #23
HarleyRider68's Avatar
HarleyRider68
ORIGINAL: dtjackten
OH just a quick note, when u torque them down i think there r 5 (not positive) bolts holding the lifters down, then u bolt then down work ur way in qually.... do not go in a row..... just fyi
Also, make sure everything goes back in EXACTLY how it came out. The oil supply passages run through therods that hold the rockers.
Old Mar 7, 2008 | 01:42 PM
  #24
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
I would have to say that they r about a year of sitting,... if u r interested just make an offer....
Old Mar 8, 2008 | 02:59 AM
  #25
Izero's Avatar
Izero
no it is comming from the brass fitting i used to hook the stock pressure sender and an aftermarket one for my gauges... when i take the f'in thing off the little male-to-male brass fitting stays attached to the freakin block and i cant get a wrench in there to take it off so its just a real pain in the ***...i just need some help to like silicon the **** out of the fitting thats attached to the block so it stops freakin leaking.... :-\
Old Mar 8, 2008 | 04:39 PM
  #26
dtjackten's Avatar
dtjackten
^^ alright, i am sure we can work something out.... the best way is to accually get that peace out and put some teflon on it..... we will have to see what we can do later.....
Old Mar 9, 2008 | 03:35 AM
  #27
Izero's Avatar
Izero
it has yellow teflon on it actually... but it just didnt hold i guess so anyways where do u actually live so i can figure out distance? lol
Old Mar 9, 2008 | 04:24 AM
  #28
Kalevra's Avatar
Kalevra
I have that annoying tap too... so.. what do I have to do?
Old Mar 9, 2008 | 10:32 PM
  #29
dtjackten's Avatar
dtjackten
a light tapping is normal, but it should go away after the engine warms up....
i live in arkport ny... 14807
Old Mar 9, 2008 | 10:43 PM
  #30
Izero's Avatar
Izero
jesus ur 4 hours away..... thats a long ways away.... hahaha lemme know next time ur in Northern NJ :-P
