Old Feb 13, 2013 | 10:43 PM
  #10191
redneck_ram's Avatar
redneck_ram
Originally Posted by techningeer
Engine balancing versus flexplate balancing are different things. If it is a used flexplate, it has already been "balanced" or whatever you want to call it IF it still has the weights on it. The weights are spot welded onto the flexplate, so it is easy to check and see if any weights are missing.
right, but wasnt it put on a certain way at the factory? or is there a groove or something to line it up?
dont want to destroy the motor before i get to even fell the power.
Old Feb 13, 2013 | 11:06 PM
  #10192
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by gdstock
[SIZE=3]Did they kiss you?[/SIZE]
Balanced involves a process of rotating at high speed (or sometimes low) so if it is not still attached, it really isn't balanced any longer. It is just weighted.
No. Thank God.
Old Feb 13, 2013 | 11:08 PM
  #10193
QuadCabLuv's Avatar
QuadCabLuv
It will only go on one way
Old Feb 13, 2013 | 11:43 PM
  #10194
Wombat Ranger's Avatar
Wombat Ranger
^^^ Yea what he said. One bolt if offset which makes the flexplate only able to install one way.
Old Feb 14, 2013 | 12:09 AM
  #10195
gdstock's Avatar
gdstock
Originally Posted by redneck_ram
so if the flexplate is no longer on, and i put one on, will everything be ok? because the 360 is externally balanced...
Look at condition, and make sure weights appear to be similar size. Excessive size comapred to another weight, large number of weights, or damage to flexplate are the things I would look for. Maybe other thing is if weights were there and are now gone.
Old Feb 14, 2013 | 06:40 AM
  #10196
redneck_ram
you guys are the best! i didnt realize the bolt pattern was offset. i thought it was an even bolt cirlce.
thanks again!
Old Feb 14, 2013 | 08:01 AM
  #10197
stewie01's Avatar
stewie01
At the shop getting rotors installed. This is the first time I've taken my truck to the shop for anything, except tires.
Old Feb 14, 2013 | 08:07 AM
  #10198
renardk764's Avatar
renardk764
Installed new tires, got an oil change, and filled her up. Woot! By by to a thousand bucks, ugh!
Old Feb 14, 2013 | 08:21 AM
  #10199
stewie01's Avatar
stewie01
Truck needs new hub assembly on passenger side
Old Feb 14, 2013 | 08:56 AM
  #10200
aofarrell2's Avatar
aofarrell2
one bolt is offset so it is impossible to install it wrong.
