Old Oct 17, 2010 | 11:50 AM
  #4791
DirtRider1357's Avatar
DirtRider1357
Thanks, Ill definitly do that.
Old Oct 17, 2010 | 08:37 PM
  #4792
Sheriff420's Avatar
Sheriff420
I'm about to change my passenger window motor, in the dark, in the cold... ugh.
That thing has been making a clacking noise when I first put it down for a while and it finally decided to go out on me, in the down position.
Old Oct 17, 2010 | 09:16 PM
  #4793
Of course. If it failed in the Up position, you would just blow it off till spring. Can't have that now can we?
Got some shop time scheduled for saturday. Going to install my modded kegger, and DRASTICALLY reduce my oil consumption. I go thru three quarts in a week...... maybe 150 miles.........
Old Oct 17, 2010 | 09:21 PM
  #4794
Gary-L's Avatar
Gary-L
Veteran: Navy
Cripes! That sounds like my truck on the way to Colorado Springs -- except I was blowing almost 1-1.5 gallons of coolant between gas stations.
Old Oct 17, 2010 | 10:03 PM
  #4795
004x41500's Avatar
004x41500
well i finally installed my 102. came out perfectly centered on the truck. will have pics tommorrow. decided on a 3" body lift, 4.56 gears, elocker or lsd in the front and rear, and 37x12.50-16.5 goodyear wrangler m/t military OZ tires.
Old Oct 18, 2010 | 11:35 AM
  #4796
Sheriff420's Avatar
Sheriff420
Well it isn't my window motor after all.
It's that little plastic/teflon wheel that holds the regulator in the track.
So the window was binding up because it was off the track.
Old Oct 18, 2010 | 11:38 AM
  #4797
Gary-L's Avatar
Gary-L
Veteran: Navy
Old Oct 18, 2010 | 12:06 PM
  #4798
Sheriff420's Avatar
Sheriff420
Not so worthless now, is it?
Old Oct 18, 2010 | 01:29 PM
  #4799
Andrew2500's Avatar
Andrew2500
Just replaced my leak detection pump. Bought one on Ebay for $30. No more CEL!
Old Oct 18, 2010 | 02:25 PM
  #4800
004x41500's Avatar
004x41500
theres a TSB out about the LDP Misdiagnosis.
TSB#18-01-00
NUMBER: 18-01-00
GROUP: Vehicle Performance
DATE: Feb. 4, 2000
SUBJECT:
Misdiagnosed Leak Detection Pump Systems With DTC P1494, P0442, P0455, OR P0456 MODELS:
1997 - 2000 (AB) Ram Van
1997 - 2000 (AN) Dakota
1997 - 2000 (BR/BE) Ram truck
1998 - 2000 (DN) Durango
1997 - 2000 (FJ) Avenger/Sebring/Talon
1997 - 2000 (JA) Cirrus/Stratus/Breeze
1997 - 2000 (JX) Sebring Convertible
1997 - 2000 (LH) Concorde/Intrepid/LHS/3OOMNision
1997 - 2000 (NS) Town & Country/CaravanNoyager
1997 - 2000 (PL) Neon
1997 - 2000 (PR) Prowler
1997 - 2000 (SR) ViperNiper GIS
1997 - 2000 (TJ) Wrangler
1999 - 2000 (WJ) Grand Cherokee
1997 - 2000 (XJ) Cherokee
1997 - 1998 (ZJ) GrandCherokee
DISCUSSION:
During evaporative system diagnosis, Leak Detection Pumps have mistakenly been replaced. A thorough inspection for pinched, kinked, or disconnected supply vacuum lines (as currently listed in the Powertrain Diagnostic Procedures) is a critical step in diagnosing DTC P1494 (LDP SW OR MECHANICAL FAULT). Additionally, the other evaporative leak faults (DTC P0442 - SMALL LEAK, P0455 - LARGE LEAK, and P0456 - VERY SMALL LEAK) should have the supply vacuum lines examined for pinches or kinks prior to any LDP component replacement. The supply vacuum lines should be checked from the engine compartment all the way to the fuel tank, including the LDP and purge system.
NOTE:
VERIFY ALL RELATED SUPPLY VACUUM LINE ROUTINGS FOR PINCHES, KINKS, OR DISCONNECTION'S BEFORE REPLACING LDP SYSTEM COMPONENTS. POLICY: Information Only
