The Official 2nd Gen RAM Forum OT thread
Old Aug 22, 2013 | 03:44 PM
  #12031
Johnn123's Avatar
Johnn123
^ Puke
How is it GM takes vehicles that look bad and make them worse? Even the canyon looks awful...
Old Aug 22, 2013 | 04:52 PM
  #12032
Gary-L's Avatar
Gary-L
Veteran: Navy
That design was stolen from Honda.
Old Aug 22, 2013 | 05:36 PM
  #12033
I spent $30 on mine....
Old Aug 22, 2013 | 07:16 PM
  #12034
BBartow's Avatar
BBartow
I thought they weren't making Canyons/Colorados anymore, just like Dakota and Ranger.
Old Aug 22, 2013 | 07:18 PM
  #12035
Johnn123's Avatar
Johnn123
Originally Posted by beginningjockey
Cold air intakes are only good for noise and appearance. The stock airbox on these Dodges outperforms CAIs on stock motors, dyno test proven.
Got any links for that tech? Google isnt being kind to me...
Custom build or off ebay? I got one for my old truck off of ebay for $60.
  #12036
aofarrell2's Avatar
aofarrell2
See the problem with CAIs on our trucks, is most take air from the engine bay, and not from the paneling, which is outside the engine bay, so first off it is sucking in warm air obviously, but even if it did keep the air cooler, there are more problems, the plenum has coolant flowing through it, so obviously it is plenty warm inside the intake, a warm engine will have no problems heating up cold air, there's a reason engineers did that, it is to help the engine warm up faster to reduce emissions. Ford uses a special valve to only introduce coolant into the intake when the engine is cold for the same purpose (not saying their system is better, just pointing out what engineers do). Then there is the issue of a PCM, unless it is tuned to match, the intake air sensor will read a different temperature and throw PCM calculations off, if even slightly, which could hurt performance. Colder air is denser, but the PCM doesn't know that, it reads barometric pressure and counts that against tables inside, it doesn't take air temperature into consideration in those tables. Put it this way, that IAT sensor is there to only help the engine determine winter conditions, and to reduce emissions.
Lecture completed, apologies if this was off-topic...
  #12037
BBartow's Avatar
BBartow
Mine came with one.
Old Aug 22, 2013 | 07:19 PM
  #12038
aofarrell2's Avatar
aofarrell2
Later yes I will post some more info.
Old Aug 22, 2013 | 07:26 PM
  #12039
stewie01's Avatar
stewie01
That's why I have a 14x3!
Old Aug 22, 2013 | 07:28 PM
  #12040
Johnn123's Avatar
Johnn123
Originally Posted by BBartow
Mine came with one.
I wanna see the video of how that happened! Musta been one sweet jump.
Awesome thank you!
