Hughes Engines, inc
Old 09-09-2011 | 02:54 PM
MoparPat2's Avatar
MoparPat2
You are wasting your time and money dealing with Hughes Engines. I paid them over $5,200 to rebuild my numbers matching 440 in my Coronet R/T. They claimed that it makes 525 HP. It dynoed at 287 HP on a G-Tech and ran 15.4 in the quarter mile, .2 slower than the stock engine that had 104,000 miles on it.
The engine used a quart of oil every 100 miles since start up. The intake gasket blew at 450 miles and I found that the center two passenger side intake bolts were finger loose. Then a valve seized up at 2,000 miles and the oil pump failed at 3,100 miles.
I took the engine to Gary Stanton Racing to be examined, measured and inspected and found that the cylinder bores were out of round by .0035 and were bored .043 over when .030 over pistons were used. This caused oiling of the plugs which made the already limping engine run worse. A valve seized up in the open position because they machined the valve guides too small on the ID and then hammered them into the heads. When the valve seized in the open position, the piston came up and smacked the valve back into it's seat and bent it. Then when the cam turned and tried to push the push rod to lift the valve, the push rod bent and fell into the lifter valley because the valve was bent and seized.
In typical fashion, Dave Hughes said that this was all my fault and he wasn't going to back any of the poor machine work and assembly that he claimed was done by a disgruntled employee that he had to fire two weeks after building my engine.
It was all my fault because I started the engine. If I had never started the engine, I would not have had any of these problems.
"Heads you lose" when dealing with Hughes Engines, his "Heads you win" slogan is a joke. Poor quality, poor attitude, insulting and nasty toward cash paying customers and non-existant customer service. Once they get your money, you are done.
$5,200 for 3,100 miles? And destroyed my numbers matching engine to the tune of costing another $5,500 to get it fixed and I had to go .060 over with new pistons to fix the block. The heads were destroyed because he over ported them.
I am going to do everything that I can to make sure that he does not rip off any of you guys. And before he tries to discredit me, let it be known that I am a senior design engineer at Holley Performance. He talked to me like I was an idiot and would not even reply to emails. When I called him, he talked to me like I was the dumbest SOB on the planet.
DO NOT SPEND MONEY WITH THESE CLOWNS, you will regret it believe me.
Quick Reply: Hughes Engines, inc
