Cold Start Idle Issues
Old Aug 16, 2010 | 11:14 AM
mnewbolds's Avatar
mnewbolds
Question Cold Start Idle Issues
I'm having this issue now with cold start idle. If I don't let it run this cycle it runs like crap. Is this normal for these motors? Or is there something I missed? I've done the Hughes Plenum and changed the IAC 3 times now. New gaskets and all. Here's a vid to further explain.
http://www.youtube.com/watch?v=qqKlm_PbT0g
Old Aug 16, 2010 | 10:19 PM
mrfarrell's Avatar
mrfarrell
mine did this when the tps went..i have a standard thou but should be similar when i would coast up to a light in neutral the rpm's would jump up like they couldnt find idle also..
Old Aug 16, 2010 | 11:56 PM
mnewbolds's Avatar
mnewbolds
It will do that occationally when I come to a stop and put it in park or neutral. I removed the EGR, cleaned it, lubed the shaft, (HHAAA), and seafoamed it. Not much smoke so it must be clean. Runs like new now. Will have to see if the idle does that again tomorrow morning. It seems like it was searching for vacuum if there was a way to describe it. Now it seems fine but I'll let it sit over night before I check it.
Old Aug 18, 2010 | 01:57 AM
mnewbolds's Avatar
mnewbolds
Checked the TPS with the new multi-meter. It's fine. Still running a little rough. Man, I need another Beer.
Old Aug 20, 2010 | 04:55 AM
botta's Avatar
botta
i had the same problem with mine it was the EGR valve located next to the distributor cap towards the passenger side
Old Aug 20, 2010 | 07:18 PM
mnewbolds's Avatar
mnewbolds
Read the Post #3. Not the EGR valve. Starting to look toward the MAP or MAF sensor. Still at a loss.
BUMP!
