New Build Sheet/Probs/PICS on the SC 408 Stroker Indy 500 Ed.
So does anyone have ideas or suggestions about the DTC's posted above?
"1st code, could have a 160 deg thermostat, need a 180stat.
2nd one, not sure, possibly saying the cam sensor in the dist is causing an issue.
3rd one possible short/cut wire in o2 sensor in the cat (does it even have a cat or sim?)
The high idle could be caused by some of these codes &/or the tps is bad."
---If it is easier to go through email...that is good too! bigslick050@gmail.com
Also how can you tell what degree stat you have? When I changed to a 180 stat in Betty, I didn't notice any specific markings on it....not that I was looking at the time. It is stamped into the ring or something? Screw it...I'm just gonna pop in a new 180 today....
Also did anyone have thoughts about the speedo being way off? Possibly a bad VSS or something?
Also the truck was running good no DTC's idling fine on Sept 2 when I first looked at it. The PO has not worked on it at all since I originally scoped it out. Like the problem started on its own...just thought I would add some xtra info
