hypertech power programmer III code 6E
Old Oct 7, 2010 | 08:43 PM
jchunting's Avatar
jchunting
Default hypertech power programmer III code 6E
i recently purchased this programmer on ebay for my half-ton and when i went to install it this code 6E came up and said it couldnt read my vehicle identification. i was wondering if anyone has had this problem before and what did you do to correct the problem. anyone help or suggestions is really appreciated
Old Oct 7, 2010 | 10:10 PM
bigslick050's Avatar
bigslick050
I have the same exact programmer and never had an error code before...
If you bought this used...I'd say chances are that it is locked up or for a different year truck. You may need to send it in to Hypertech and have it reset to work
Old Oct 9, 2010 | 02:17 PM
dhvaughan's Avatar
dhvaughan
call hypertech and ask them what that code means and is there any work-around.
there is also a forum member from hypertech that you can PM.
Hypertech Support
i doubt that your primary problem is Vin Locked, or else it would specifically say so.
i've also got an 01, and i've also got a hypertech laying here in the shop that i used for awhile. it did do a slight timing advance, but it wouldn't adjust my speedometer for larger tires. hypertech has not yet been able to tell me why that is or offer a solution.
don't spend any more money on that unit.
Old Oct 9, 2010 | 02:27 PM
Good possibility that the programmer is VIN locked, as the previous owner didn't return his vehicle to stock before selling it to you.
Old Oct 9, 2010 | 10:57 PM
bigslick050
My thoughts exactly.
Also, if you gotta spend more $$$ to make it work, I suggest you toss it. Not the 'best' programmer around. If I had know about Hemifevers SCT, I would have it instead of my Hypertech for sure...still saving up to get one......eventually
