BOGGS and BOULDERS!!
Old Jan 18, 2011 | 08:02 AM
  #21
Sheriff420's Avatar
Sheriff420
The axle and transmission vent tubes are on the passenger fender right behind the shock tower. If you want to see where they hook up then follow them down to the transmission and the axle. You can see the one on the axle just by looking at the CAD unit. I'm not sure where the transmission vent hooks up.
Old Jan 18, 2011 | 08:22 AM
  #22
hutch311's Avatar
hutch311
ill have to take a look. so when you say extend them.. is there a preferred place to extend them to?
Old Jan 18, 2011 | 11:48 AM
  #23
As high as you can get them. You do NOT want them someplace where they might suck water, or anything else for that matter. Routing them up into the cowl, where the air intake for the heater is wouldn't be a bad place.
Old Jan 18, 2011 | 04:12 PM
  #24
hutch311's Avatar
hutch311
sounds like a good idea. what about the rear diff
Old Jan 18, 2011 | 04:49 PM
  #25
Get a bunch of hose, and run it up to the same spot. On my old blazer, I ran the tubes from the rear axle, t-case, trans, and front axle to a 'junction block' type of deal, and then ran a single hose, with the funny little cap on it, up into the protected area of the cowl. I could go thru some pretty deep water (lapping up onto the hood....) with no worries.
Old Jan 18, 2011 | 05:22 PM
  #26
hutch311's Avatar
hutch311
sounds like a plan. thanks for the info!
