let me know what u think + advice
Old Apr 10, 2011 | 09:41 AM
ownsjo's Avatar
ownsjo
Default let me know what u think + advice
tell me what u think of my ram, and that ticking noise, sounds like exhaust leak when i just installed the headers, looks like the welds are a lil bad idk let me know
http://www.youtube.com/watch?v=zsFKAmOkQfw
Old Apr 12, 2011 | 09:04 PM
Ram_Me's Avatar
Ram_Me
Sounds like a leak to me. It might not be the welds though, the header bolts are more than just known to back themselves out of the heads. I had this happen to me twice. I got tired of the leaks and got these bolts that can be physically stopped from turning. I believe they are called stage 8 bolts. I got them from summit.
Might get more help if this was moved to the tech section.
Old Apr 12, 2011 | 09:44 PM
PurplDodge's Avatar
PurplDodge
Haha, are you speaking spanish at the beginning?
Sounds like a leak to me. Could be the gaskets, the bolts backing out, or the welds are bad. If those headers are worth a crap, they have a warranty and if the welds are bad you can send them back.
Old Apr 12, 2011 | 10:36 PM
pcfixerpro's Avatar
pcfixerpro
I've never seen headers installed like that with those bolts. If it were me, I would have double nutted them so the first nut can't back off... that said, it does you no good if the bolt itself manages to back off somehow... which is the same problem with regular header bolts so im not sure this method gains anything. Interesting idea though!
As far as the leaks... it does sound pretty bad. I'd suggest seafoaming the truck, and instead of watching the smoke show at the tail pipe, have someone watch the header and see where the leak is. That's what I would do to see if it is the gasket, the header itself, or the collector.
Good luck!
Old Apr 12, 2011 | 11:10 PM
97Rampowerhouse's Avatar
97Rampowerhouse
Good luck!
+1 on the bolts the stage 8 bolts from summit. Ive had them on my truck with my headers and havent had to mess with them since
