1997 5.9 swap to 2001 5.9
Old Aug 16, 2011 | 09:49 PM
welchj69's Avatar
welchj69
Default 1997 5.9 swap to 2001 5.9
i have a 1997 1500 with a 5.9 in it now engine blew was told the 2001 5.9 was the same so i bought one now i have notice that there are 2 temp sensors on my old engine and only one on the 2001 what do i do with the one that i cant use
also i have notice that the fuel rail is different along with the injectors are different will the 1997 injectorfit in the same injector place and just change the rail or do i have to change the whole intake? all help would be great thanks james
Old Aug 17, 2011 | 01:47 PM
97tn4x4's Avatar
97tn4x4
Just take the intake off your old motor and put it on the new one.
Old Aug 17, 2011 | 01:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And fix the plenum while it's off. And use the flexplate/flywheel and the front crank pulley from the 01 5.9
Old Aug 25, 2011 | 08:50 PM
welchj69's Avatar
welchj69
ok so the engine turns over now i dont have spark at the coil or power there or at the injectors change crank sensor and cam sensor still now power either spots and asd is getting power and i replace relay to be sure still no spark
