Help - My Truck Won't Run
Old Oct 22, 2012 | 01:14 PM
  #171
drewactual's Avatar
drewactual
pour some freeze dried chinamen in the tank.. those are some industrial little cusses, and once they collect some moisture, they'll get right to work.. you'll never even know they're there, unless you listen real close and are fluent in mandarin..
Old Oct 22, 2012 | 02:27 PM
  #172
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by VWandDodge
So, are there any suggestions where I should start with this?
Trade the truck away for a bicycle and a goat wagon. It might leave enough in your budget for hookers and blow, or at least a cousin and a rack of Milwaukee's Best Light.
Old Oct 23, 2012 | 12:29 AM
  #173
dhvaughan's Avatar
dhvaughan
Originally Posted by dhvaughan
i think GD is onto something. if your truck was originally sold in California its probably got a Pacific Timing Module, PTM. Since your truck is in Oklahoma, it will need to be replaced with a Central Timing Module, CTM. I'd send you mine, but it won't work either because its an Eastern Timing Module, ETM.
you'll need to go to the dealer for this type of service.
you bastards didn't laugh at my Eastern Timing Module. c'mon that was funny !
Old Oct 23, 2012 | 10:09 AM
  #174
Gary-L's Avatar
Gary-L
Veteran: Navy
You mean there isn't a difference in the timing modules?
Old Oct 23, 2012 | 11:39 AM
  #175
Have you downloaded the "No Start" app for your smartphone? It works wonders. Download the app, then point your phone at your lawnmower. Grab your left ******** between your big toe and your elbow while chanting "imasmellysonofabitch" for a minimum of 15 days. After this, you MUST give the dog a bath with tepid water. Then start the truck. I had a cousin from a guy that was married to another woman that went to a different high school in the early 1920's provide me with this helpful information.
Old Oct 26, 2012 | 02:21 AM
  #176
Josh_Putman's Avatar
Josh_Putman
Does your truck really WANT to run? It has to want to, not just because you tell it to.
Maybe it's lonely. You should invest in another truck that it can look up to like a big brother. Give it some motivation.
Or get some racy little European car to keep it company. That should get it's motor running.
Old Oct 26, 2012 | 06:32 PM
  #177
Wombat Ranger's Avatar
Wombat Ranger
Just about the funniest thing I have ever read
Old Oct 26, 2012 | 09:02 PM
  #178
gdstock's Avatar
gdstock
Thank you for that visual......
Old Oct 27, 2012 | 10:41 AM
  #179
dhvaughan's Avatar
dhvaughan
VW - i don't think you have properly motivated your truck to want to run. you've sat around on your *** and allowed your truck to grow soft and lazy. what it needs is discipline and motivation.
in order to motivate lazy people i've always been taught to light a fire under their ***. that has always worked.
so i think you should do the same for your truck. its time to get mean. its time to get nasty. you should build a pretty large fire under your truck's ***. right about the middle, maybe a little towards the rear end, perhaps right under the gas tank. a big roaring fire with some plastic that will burn really hot. maybe throw in about 10 gallons of diesel fuel.
i think this will permanently solve your problem.
Old Oct 27, 2012 | 11:06 AM
  #180
stewie01's Avatar
stewie01
Best advice so far! VW, when you try this it's important to get a video and post it to YouTube and link to it here, so we can see if you did it right
