oakie
Old Oct 17, 2011 | 03:50 PM
oakie's Avatar
oakie
Question oakie
i have 1994 2500 2wd w/12valve.i have just completed a brake job,done right,new rotors, calipers,pads,rear shoes,springs,wheel cyn.new lines front to rear,and new master cyn. all bleed well.i have great pedal unill truck is started.pedal then goes to floor????? help. thanks,oakie
Old Oct 17, 2011 | 05:45 PM
BackwoodsRam's Avatar
BackwoodsRam
hey oakie can you please add the info about your truck to your sig. it will keep you from having to type it everytime you have a problem. your also in the wrong section. as for your issue sounds liek you have a leak somewhere. did you double check the lines behind your? gas tank
Old Oct 17, 2011 | 08:02 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Speaking from experience here, what type of MC did you use? Brand new or a reman?
My truck had a bad MC, took it to the shop where the put 2 remans on it and one new one.
The new one worked without a hitch.
I would start there.
Old Oct 17, 2011 | 10:39 PM
mrfarrell's Avatar
mrfarrell
bleed the brakes with the truck running...
Old Oct 25, 2011 | 09:14 AM
oakie's Avatar
oakie
thanks for help. new master solved problem.
