Trailer Wiring
Trailer Wiring
I have a question on trailer wiring. Trying to hook up a brake controller and 7 pin on my 98 ram sport. It has the controller plugin by the fuse panel. It also has the relay and fuse for the factory trailer plug. The part i'm confused on is that there is no wiring that I can find to the rear on the truck. Anyone seen this before? Looking like I will have to run my own wiring to the rear of the truck.
Todd
Todd
Yeah I,ve pretty much figured on having to run them, I don't see anything at the back of the truck. But I know the po did some work back there as to a couple other wires had plugs cut and rewired. Just no sign of the stock trailer wires. If i'm reading right I can plug into the brake wiring with the brake under the dash and tie the wire from the plug in the back to the blue wire coming out of the fire wall. Thanks for your input as I know this topic has been ? to death. Just haven't seen my situation anywhere.
The wiring usually runs along the driver side frame rail. I would check further up the frame rail and see if it may be wrapped up somewhere.
Also check out this link for some other ideas on wiring it all up if there is no factory wiring.
http://www.etrailer.com/Custom-Fit-V...eid=1998306072
