Output Shaft Adapter
Old Nov 7, 2011 | 01:54 PM
Rosyfloater's Avatar
Rosyfloater
Default Output Shaft Adapter
98 Dodge Deisel 4x4 manual 5 speed has a crack in the output shaft adapter (probably not the correct name). Are there after market adapters available as the is an obsolete part from Dodge? Or maybe used adapters available without have to buy the whole transmission?
Old Nov 7, 2011 | 02:15 PM
Housing between trans, and transfer case? Junkyard is going to be your best bet.
Old Nov 16, 2011 | 08:16 AM
Rosyfloater
Default Output shaft adapter
HEYYOU, I found an adapter made of steel that was made for the 4500 transmission, deisel application, don't know if it was for an earlier model or aftermarket but it bolted right up. I got it from UTE WAREHOUSE PARTS in Phoenix, Az. for about a third the price of an aluminum Dodge part if they had it. Thanks
