what gauges do u have?
Old Nov 18, 2011 | 11:19 AM
  #31
biggreen2500's Avatar
biggreen2500
sweet well i got my 3 gauges i need tranny temp,oil, and vacuum
so how does a vacuum gauges help u save fuel? i understand why its important to have incase i get a vacuum leak.. but saves fuel how?
beside the tranny temp and oil pressure and vaccum are there any other gauges i should consider? cause i can also just mount more at the bottom of my dash
fuel pressure maybe or ?
Old Nov 18, 2011 | 11:23 AM
  #32
Gary-L's Avatar
Gary-L
Veteran: Navy
It helps by providing feedback as to how hard the right foot is pushing the accelerator pedal. Push too hard, too quick, and the needle plummets quickly vs pushing slowly and steadily results in a very gradual decrease in the needle's action.
Old Nov 18, 2011 | 11:43 AM
  #33
biggreen2500
oh okay that makes sense.. thanks man... i'm gonna have to order the gagues up soon so i have some cool stuff for christmas lol...
Old Nov 18, 2011 | 12:48 PM
  #34
8uzzsaw's Avatar
8uzzsaw
If thats what you need to make you save fuel, you werent trying to begin with! Lol
Old Nov 18, 2011 | 03:11 PM
  #35
UnregisteredUser's Avatar
UnregisteredUser
I'm going with fuel pressure just because these darn pumps have a habit of losing pressure over a long period of time before finally the truck won't run, and I hate being taken by surprise. I hate hate hate hate it! If it weren't for that characteristic of these trucks and/or my irrational hatred of broken 5h17 I'd think the fuel pressure gauge a bit excessive.
Live like ya wanna live, man.
Old Nov 19, 2011 | 03:17 AM
  #36
biggreen2500
well i was just asking cause i found the 3 gauge pod piller thing and then the 3 gauge pod for the dash now i'm trying to think if i can come up with 6 gauges i need lol
Old Nov 19, 2011 | 10:07 AM
  #37
UnregisteredUser
Mine are (purchased, not yet installed) two diff temps and trans temp in the dash pod, fuel pressure, manifold vacuum, and tachometer in the pillar pod. My truck's a base model so it has a big gas gauge instead of a tach in the instrument cluster.
The diff temp gauges are superfluous unless you're really working the truck hard with lots of weight in the bed or in a trailer or do stream crossings that result in water in the diffs.
Old Nov 19, 2011 | 01:42 PM
  #38
drewactual's Avatar
drewactual
Saving gas with a vacuum gauge: keep as much negative pressure as possible to save fuel.. you would be surprised how much and often you needlessly load the engine, and the changes are so tiny in sound they are really hard to hear.. add a radio or traffic, you're not going to be able to detect it at all..
When I installed one, I found the difference in 10psi and 15psi was like a millimeter of pressure on the go foot.. I also found that positioning my foot to catch a different angle on the pedal allowed less likelihood of accidentally over loading..
If you disregard road speed all together, and focus on engine load, and give just enough load to get the job at hand done, your mileage will jump way up... That's not practical, but its possible.. what is practical is stopping the ramp up/ ramp down game of loading the engine, then shaving speed by coasting even a second or two, just to load it again.. if you get close to a steady 'plane', you'll increase your mileage too.
Old Nov 19, 2011 | 03:45 PM
  #39
merc225hp's Avatar
merc225hp
This is why I am adding one to my truck. What did you come up with for an adapter to utilize the schrader valve for the sending unit?
Old Nov 19, 2011 | 05:50 PM
  #40
UnregisteredUser
I'm not entirely certain that I'm going to connect to the Schrader valve. The more I think on it the more I like the idea of teeing the line ahead of the fuel rails to keep unnecessary mass off of the fuel rail.
I'll make more noise about the ordeal when I get around to doing it.
