Wrenching Carnage!
Sliced my thumb knuckle down to the tendon (stitches only, no tendon damage luckily) putting a body lif on an old truck I used to have. Finished the lift then went home, cleaned up and went to hospital for stitches.
Replacing a u joint on my moms jeep liberty today I was using an impact socket and a 32oz ball peen hammer, instead of a ball joint press...
Yep....... smashed my thumb, broke the tip of my thumb, and got 9 stitches.
Hurt like a ****. Happened around 1130 this morning, still bleeding a bit as of 820 tonight.
Still numb from the novacaine. No pain killers other than tylenol, or ibuprofen.
^Damnit man... Hope she heals fast.
Worst things I ever done (sorry no pics...):
Grabbed a piece of bright red molten metal (not on purpose), burned my skin white... THAT hurts. I can still find the spot today - though no scar for whatever reason. Couple weeks later burned myself on a dark red welding rod - that hurt worse for whatever reason and it wasn't as hot. Little bit of honey on it and it healed fast.
And messed my back up bad when I got myself pinned between the front seats and the dash. I was trying to install the trailer brake controller, was on my belly on the seats, and slipped down in a BAD position. Both my cell phone and two-way radio were out of reach so I had to wrench myself out of it. To this day my back is still messed up.
That's a good un.
The numbness around the wound is starting to turn to pain but past my knuckle is still numb from all the novacaine.
Oh, and I have medicaid so no med bills for me!
Though I probly shouldn't be happy that I have medicaid, but its better than nothing!
Certainly better than nothing.
And I certainly don't hold it against you.
I usually prop the caps on a couple boards, and drive the shaft down with a BFH, so the cap on top will pop out. Then, just roll it over, and drive out the other side. Works good, and is a LOT less dangerous for the fingers.
And I certainly don't hold it against you.I usually prop the caps on a couple boards, and drive the shaft down with a BFH, so the cap on top will pop out. Then, just roll it over, and drive out the other side. Works good, and is a LOT less dangerous for the fingers.
I bet more than yeouch. I'd say partial loss of feeling for several years until the nerves repair themselves. My first Dodge was a 66 D-100 and I was having trouble getting the old oil filter off. I drove a screw driver through it and began twisting (it started turning), but my hand slipped due to dirty oil all over me and I got 12 stitches and some nerve damage that eventually healed. My Dad was more like others on here and hammers loved his thumbs. K.
